wf4 su windows 7 64 bit
  • Thread starter Thread starter Nibbio4
Nibbio4
Hello, everyone.
I installed wf4 m220 on windows 7 to 64 bit.
we have a single shared and placed config.pro on the server, on the xp64 machines we load it without problems instead on this new with seven we have the problem that does not charge it another machine with the local config does not have this problem.
have you had such problems?
Hello and thank you
Hello, everyone.
Hello and thank you
proe searches for the config.pro in the "text" folder or in the program boot folder. How do you start proe from this pc? If you have a link check its properties, the "from" field must correspond to the program's boot folder.
the link pointed directly to the boot directory where there was the config.
I tried to launch it with the local config and anyway I have problems reaching common folders on the server, so for now I solved by bringing a copy locally.
at this point I believe it is a problem linked more to the management of disks in Windows 7 network
seems like an administrative privilege problem (what kind of user you have on the machine) ?
we have a machine with seven 64, the rest with xp 64 and server with win server 2003 .
on the machine with seven we have no problem from wildfire 3 onwards.
apart from the crap that is seven ... of course:-)
