gil
for large tubes, what is the advantage of a pipe made with helical welding, compared to the classic longitudinal welding? under attach photos of helical welding tubes for clarity
"corti" is x 50cm or 2mt?helical welding can be made a continuous process in which the diameter of the pipe is one of the process parameters. the longitudinal one must necessarily be a batch process.
from the structural point of view the pipes are equivalent because the welding restores the continuity of the material. Moreover for "corti" tubes the longitudinal welding is less stressed than the helical one, so the thing still does not work.
up to about 500-1000 times the diameter the tube is considered short. I mean all the conduct, not the single piece of course."corti" is x 50cm or 2mt?
