RS4
Bye-bye.
the standard used is the cl ever heard lc..... anyway I think it is only an Italian translation made over the years on the yards deriving from the Anglo-Saxon standard
in the aeronautical sector is very used the term center line because the aircraft is divided into stations, each type of center line has the suffix of the organ that interests, all the axioms and subaxioms are among them indexed e.g. between hinges if we talk about center line hinge and many others.., then even diagrams of all the center line would be the configuration of how will be designed and in future built the aircraft
the bl0 instead we speak building line ie the center line that crosses in a longitudinal way the aircraft and indicates station bl0 where from it will be listed
allego 2 images
foto 1 indicates the center line hinge quoted at 2.50" compared to the center line spar longherone structural
foto 2 indicates the center line hinge and recalls the corners and movements of the hinge going to read the respective notes
allego 2 images
