Pamak
I have a problem with the coupling of a 4 fixed position divider.
the positions are obtained by means of a pin with a tilted head of 20° (and radiated) that of graft in a female with the same profile but with 0.1mm of play.
the result that I would like to get from the axieme would be to see the linear excursion of 6mm of the pear by turning the divider (in practice every time the quarry the pear starts, when the pear comes out from the quarry the pin is retracted)
I gave a minimum and max value for the linear race (with difference of 6mm) and then I tried both with the command "camma" and with the command "profile coupling" but I can not get the desired result (it gives me some errors)
How to do that?
thanks in advance (p.s. use sw2010)
allego 2 images to make the idea of the problem
How to do that?
