what tool do i do with?
Mold
I have to make the cut in a piece of furniture.
In practice I have to make a small subsquadra in the injection carrot.
with which instrument do I realize it?
Should I use a drill?
electroerosion with orbit.
alternatively on the milling machine with a bare that has the possibility to widen during rotation.
last option do a small thread preforating with a larger hole tip required for the thread.
for example do a ø7.3/7.5 and fillets of m8. this is the method used once, it works well but it has the defect to create plastic parts that are detached from the printed and go around the mold.
I forgot the simplest option:
a bushing with head is inserted in the mobile plate, you can also find commercial, on this you realize the tiramatarozza with the lathe.
last option, a little coarse, with a wider conical cut in the lower ø you place at the center of the hole at the desired depth, then you move to x and y from both sides to create the subsquadro necessary to the tiramatarozza.
> > a bushing with head in the mobile plate, also commercial,
> > on this is the tyramatarozza with the lathe.
Okay, thanks.
The tyrant or the tyrant is a sub-squadra of a few tenths, otherwise the expulsor may not be able to throw out the materozza, right?
That's right.
in some cases you can also reach 1 mm in ø, if you need a strong "tiro" or with soft materials.
