on archicad drawings 1:1.
the scale you can change it whenever you want and if you have designed fine archicad increases and automatically decreases the detail
i.e. in practice you can start drawing in cm as archicad does not need scale settings?
Do I have to set the scale when for example I have to import a design in autocad?
What does "increase and decrease automatically" mean to increase I have to zoom or there is an automatic system, in which case how do you set up?
you plan in meters, if you want in centrimeters you have to set it up. the change of stairs is automatic, because if you select the scale to 100 the parametric objects have a degree of detail, if the selection to 50 a more detailed, etc.
Maybe you talk about the unit of measurement, which is different from the scale. When you write "1" if you want it to be a meter or an inch, it depends on the measuring unit.
