where am i wrong to use the "physical" positioning of the advanced design module?
  • Thread starter Thread starter Kaji
Hi, in the tree I don't see any constraints, they have to be created to see the movement.
the "physical" movement that I would like to do and that you see in the video also works without constraints; if you look at the tutorial the constraints and relationships are used only by minute 2:20 then when paul hamilton creates a new relationship to attribute to the pin the function of the "fixed" part, but the chain drag works regardless of this bond, the introduction of the bond only serves to prevent the pin from moving and forcing the pinion to rotate around it when it is dragged by the chain
Hi, I followed the video carefully.
I downloaded myself from grabcad a sprocket chain system, but I can't replicate what happens in the video, the only thing that comes to me at the moment is that in the video is active in addition to the relationship module also the surfacing module that I don't have because under other license, I wouldn't want to hit something.
However it is a very interesting function that I would not have found without your question.
when I have a little more time I will try to go deeper to try to understand why it doesn't work.
in my case if they select the pinion, it becomes blue, compared to the chain that is blue and turns out as "fix", while the pinion moving it stops by gearing the chain, it is as if the system does not know that it has to consider all the free elements in space.
Mar
ciao, nei commenti del video ho trovato la soluzione.
this is version 18.0 of creo element/direct modeling. i change the physical settings under the 3d copilot settings to "free" to allow the chain links and other parts to move freely. default is "fixed".
