where is 'line settings' in revit 2011?
  • Thread starter Thread starter ocraM999
ocraM999
Does anyone know where in revit 2011 there is the command 'line settings'?
I'll be blind, but I can't find him.
Mar
Mar
... is it a new command? ? ? ?
if you mean styles/spessors/models, you will find them in: gestures> additional tax ...
if you mean the type selection (during the design is model/detail) : property>graphic>style line ...
is the command used to transform lines into < invisible lines> < hidden > etc.
I have to put the interface of 2009 to have it (see attached image)
Mar
is the key with the stylograph pen icon
found.
They hid it in a ribbon called 'view' next to 'modification' and, to make things easy, they changed the icon.
igo image
Mar
... except now I'm at 2012... I have another question to ask:
after making invisible some lines, is it possible to go back?
I intend to restore the 'ante operam' display without looking for one by one and reset them manually. (the drawing is great, I did not do it so, being invisible, I do not know where they are)
Mar
Since it is a "view-based" setting (only in the current view), try to duplicate the view. you should find all the lines <per categoria="">...</per>
