wildfire5 e windows8
  • Thread starter Thread starter aserf
aserf
I am trying to install proe wildfire5 on my computer with Windows 8 operating system, and I failed.
I literally ran the installation procedure,and I wanted to know if windows8 and wf5 are compatible and if someone can help me!
hello pro/e wf5 is not supported on windows 8, on windows 7 yes but from m040 forward.
Windows 8 support starts only with creo 2.0 from m030 forward, while for windows 8.1 from m100 forward.
Thank you, so with windows8 I have no hope.
my version of wf5 is the m020, I can't even install it with windows7.
With windows 8 I'm afraid not, I'm keeping myself far away from that system.
with windows 7 instead you can, you have full support from m040 forward of wildfire 5 but they actually introduced the support from m010 and then your m020 reflects the requirement.
I made free upgrade of windows8 to windows 8.1,wf5 installation is possible according to you?
If yes, can I use the post processors I used with wf4?
I'm sorry, but did you read what I wrote about you or not?
I read what you wrote, I thought that with windows8.1 there were improvements to window8, which would allow me to install.
if a program is not compatible with a more obsolete operating system (windows 8) , let alone if it becomes more modern (windows 8.1). . .
you do not have to update the operating system but the program, then switch to create 2.0.
