window display order overlapping in the layout
  • Thread starter Thread starter Piron88
Piron88
Good morning, everyone.
I am composing a drawing board where I need to show two overlapping layout windows (in particular, an exhibition on the ground floor of a residential complex and all external accommodation, and the other shows the roof plant ). In essence, I can't make sure that the roof (filled) with restraints ) hides the shape of the building on the ground floor. I tried to use a covering entity and then with display order cover the ground floor, but nothing to do, it almost seems that the display order command does not work. Does anyone have any plans to give me? I have tried some solutions in the forum but I haven't been helpful until now :frown:
but do you want the overlap to show the outside accommodation?
Yes, I want the overlap to show both the external accommodation (which is present only in the ground floor plant) and the roof, as if I photographed the building from above.
I had already seen that post, but I wondered if there was a different method, now I realized that autocad does not allow it basic if not through "trucks" of this type. Thank you very much for the tip:biggrin:
