window display problem in comparison
  • Thread starter Thread starter Java
Java
Good evening,
I have a problem with the visualization of the projected windows in the comparative phase only in the prospects.
in practice it only shows me the davanzale because protruding from the wall and does not make the red contour of the window that is flushed internal wall. the only way to see the whole window is to set the opening of the doors to the outside but so the window disappears as well.
instead existing windows not affected by red/yellow are displayed correctly
You know how to do that? ? ?
The programme in question is revit 2022, other discussions on this matter did not go fully into the solution.
show us a screenshot of how you see them and an example of how you would like to represent them, otherwise I see it hard to help you. . .
