window with openable shutters and 2d detail
  • Thread starter Thread starter asalalp
asalalp
hello to everyone.. I attach a parametric window where you can manage
- degree of detail with particular 2d nested
- shutter opening
- crazy parameters
- frame parameters
- height, width etc.
I didn't see the family. to act on the shutters there should be a parameter, with a value in degrees, to be changed.
if it does not exist, you must change the family
It works and is done well. in fact just change the parametergrades:
upload the family, select the window and properties, at the top right click on change type and see that in the area size (type of parameters ) you find persian opening expressed in degrees (default 180°) that you can change. be careful because you can notice the change in the plant only in medium or high-level mode. Hi.
