working with advanced properties
Mike2005
good evening, I'm a semi professional solid user, I've been registered for a while and every now and then I read the new discussions, I wanted to porn a new one that doing some internal research on the site should not be present or similarly I found one that does not fully respect the request I wanted to ask you.
I find myself with a discreet amount of assemblies/parts (about 300) that present their properties within the file such as "denomination", "article", "designed by" etc...
is in fact that I find myself having to update all these properties as for example code" article,
my dream would be to be able to change these properties automatically having an excel file having a column with previous properties and another column with new ones. I hope I've explained well, or at least I hope I've passed the message of what I would like to do.
better clarify however what you need exactly:
you want to change the content of the properties (e.g. the property item has value 12345 and you want to change it by keeping the item name but with abcde value)
you want to change the name of the property (e.g. the property item with value 12345 becomes n° article but maintains the value 12345)
is an important clarification to understand how to act
in the second case try recording a macro.
logs doing the procedure on a file, check it on a next file and if it works with the task scheduler apply it to all other files.
insert the solid version into the profile
