working with .stl files
  • Thread starter Thread starter mdcompositi
mdcompositi
Hello everyone,
I have a problem with .stl files in nx4
In practice after importing them I can't find any way to get references!
I'll explain better.
if I have to use a .stl file on which there are holes to which I will screw my plate that I will have to make, how do I take the center of that hole?
Thank you in advance anyone who can help me!
Hello everyone,
If you look better you will see that there is an axa response somewhere but refresh the info: stl can be managed with appropriate packages (mach3 for example that has all the reverse part) but a little something you can bundle with smaller bundles. with the section command (drawing the association) allows you to find intersection curves in a stl.
Thank you so much!!
problem(if such you can call) solved! !
I had tried already but didn't use the right filter( faceted body)!
