yarn / import dft in autocades
  • Thread starter Thread starter mpiero67
mpiero67
Hello.
I'm piero and I have a "prophany" question to ask.
(I press that I have spulved the existing posts but I have not understood the answer I seek)
the question is: can I open/import dft files in any way, using only 2005 autocad?
if not, do there exist utilities (possibly free) to perform this conversion?
Thank you for any indication you can give me.
piero
hello and thanks for the readiness.
I have already read this discussion, and I have read it more carefully, but it seems to me that it is based on the assumption that it has itself.
I unfortunately if I do not have it, so I can only use autocad functions, or any external converters (if free).
If the answer is there, and I can't read it, I apologize for my "technical poverty" and I ask you to avoid it.
Thanks again.
piero
autocad does not matter dft files, and I do not find there are free autocad utilities that do it.
I believe that solid edge free 2d drafting I can do it for you, even if I never used it.
So I could have taken a bark.
Bye.
with this you can do, in the sense that with solid edge 2d free open dfts (which among other things displays them almost like pdf) and then save them quietly in dwg/dxf.
in workshop where work use I’m system when you have to convert to dxf drawings for machine programs.
Keep in mind that it only opens dft files and no 3d models.
Okay, thank you very much.
I recorded and I'm trying to download.
just finished (think for tomorrow:frown: ) I'll give you some proof and I'll give you some.
piero
