zero-woven in nx1953
  • Thread starter Thread starter ceschi1959
ceschi1959
hi to all users nx,
as you know after the nx12 version has changed the numbering of major releases and updates.
now we arrived at mr nx1953 which is bringing remarkable changes (already started in nx1926) in the sketch.
there is a kind of survey in the forum siemens ( https://community.sw.siemens.com/s/...etches-to-the-new-sketch-solver-in-nx-cr-1953 ) I would like to repeat here.
I am personally puzzled about the new ui to the creation of the sketch in which they removed, to simplify tell the developers, the possibility to define the direction of the sketch what can be done after with the reattach command.
I don't know how to define the thing, it's like, for example, the extrusion command vector was default z axis and if you want to change it you should re-edit the feature.
I beg those who agree with the undersigned, to open an ir and to hook it to the er9958821 regarding the possibility of choosing the direction to the creation of the sketch.
good job c.
What to say, we went from 1872 to 1953 and for all my colleagues I left the legacy sketch through 'early access feature', while I use the new. I don't know where to go... use it and then sigh.
I don't understand that too.
even the system of constraints is cryptic.
I honestly don't understand the improvement.
for me to use the new sketcher is like running with an elastic that connects my feet...
Maybe I'm too old. .
hi beppe,
I don't understand the meaning of it, they're already taking a few steps back, like putting back the possibility of orienting the sketch to creation.
I'm trying to see how our products behave with the conversion to the new sketch, it hurts me.. .
But the strange thing is that, while on the official website there is a little ferment, here in Italy we are only 'old' to have commented on the new sketch.
I'm glad you have the same feeling from the inside.
I really hope they have a few thoughts.
Maybe I'm too old, too. :
I add to my colleagues who define themselves as old as they do not understand the features and advantages of the new sketch...... as far as I am concerned it has returned very backwards , I do not see the advantages, work with nx from far 2002 , (was still unigraphics) practically since it became nx use the sketch together with extrusion or revolution for every stupid geometry that I insert or that I create was the easiest and intuitive thing. Today he's become a brainstorm, you don't handle it... I can't bind it geometrically when I think it's okay to move something and I'm going to put...ne
Well, reading this discussion put me some anxiety... we are still at the 11th and in these days the cad manager is preparing the computer structures for the passage to the new version (I don't know what you are talking about). So tell me that handling a sketch will become a big problem? will there be only this last way to work or you can choose to stay in the "traditional" way while going to the latest release?
quiet, the 'old' sketch legacy remains. and for any tip on how to activate it write me also in mp.
in the matter of minchiate they made another: until version nx 1980 (the last currently) it was not possible to select the horizontal reference to the creation of the sketch, it was necessary to use the reattach... in version nx 1980 they remitted it... but not complete: in fact there is the possibility to select the horizontal reference only via line, edge (linear) and datum axis.
Yes, yes, even that beautiful minkiah!!!! I am to the version that at creation I can not indicate the horizontal axis of the sketch! ! !
I did a session with one of the creators of the new sketch to better understand the guiding principles of the same.
what I understand is that when you create the sketch:
1. We have to put the quotas that concern us.
2. the odds that you want to command out of the sketch should be explicitly declared (this agrees to me because having in the expressions all quotas was really annoying)
3. let loose geometric constraints (just don't impose them) and let the nx resolution engine do
... at the end, once I applied point 3 (which is exactly the opposite of what I was used to doing... I mean, I used to fix geometries with constraints and then quoted) the sketch always works egregiamente. . and, of course, it is much more "elastic".
There's the 25-year-old habit of putting constraints, which goes a little raped.
hi beppe! would you have the opportunity to share a sketch in which there are only a few odds explicitly declared?
Thanks for the explanation, I'll do more evidence.
I have the bad feeling, for my mental tara, that if I don't constrain I in advance lose control of what I do.
a little like riding without reins, even if he knows the way:)
I confirm that even after I bang a few months above, I just can't get used to this new sketch, it was much better for me before. in this area, in particular, but also in others, although less heavy, for me from version nx12 to 1954, a step backwards, I worked much better before.
You?
You?
I think they beat a lot, and they don't want to admit it. they have remitted the possibility to put the parameters but only doing a boia fatigue.
then the half step back that they did remit the horizontal orientation to creation but only with line, datum axis and linear edge while in the reattach there are still all with in addition the option (fundamental sometimes) of vertical orientation, very perplexed bait.
the 'old' sketch remained legacy so I keep using it by default and I'm doing
Your answer confirms the fact that, fortunately, I haven't been completely stunned yet.
I really don't know what to say. When I see him being used by the product manager, I feel like I understand everything and I feel so cool... Then I put my hands on it and I make trouble. Probably 25 years of different sketches I can't erase them with a sponge shot.
I'll keep trying, of course, I can't do anything different. :
Good day to all,
please someone can explain to me how the cabbage removes the dots on the x,y axes of the sketch, which give me a tremendous nuisance.
and why do I do new sketch automatically hide my datum coordinate system?
good day to all,
and why do i do new sketch automatically hide my datum coordinate system?
thank you.
i never needed to remove them and i think it's not possible
