zigrinatura su impugnatura ovale
  • Thread starter Thread starter Marvel
Marvel
goodsera to all, as from title can you make the zigrination on an oval section handle? I tried to follow various video tutorials but all start from the circle and also the program, when I want to draw a spiral, tells me that you need a starting circle.
Bye!
Mar
Hello Masses, thanks to the suggestion, I'm trying but I'm not coming. I created a smaller service circle than the minimum oval size on the orthogonal plane to the handle; propeller function, which at this point is inside the handle, but the function "wrap" does not carry it on the handle.
also all video tutorials are all based on cylinder.... ?
certainly if you do not attach pictures and files it is difficult to help you.
the most practical way, and optimized as resources, is to make a spiral cut and repeat it circularly.This however on a body that does not have a constant diameter is a problem because the number of repetitions varies according to the diameter. So it seems to me to be excluded.
the winding function implies drawing all the geometry of the zigrination in a sketch. the sketch will have to have as the dimensions of the imbodiment of the oval; inside it will repeat the silhouette of the single diamond and all those that exit from the encumbrance must be eliminated this function will weigh as much as thicker is the plot and bigger the encumbrance therefore it is the case to make some evidence using a large plot or a portion of the oval. with 2013 however it does not seem possible that it wraps on non-cylindrical bodies.
a point can also come from this video
note to marginalize:
Where's the problem? you draw a circle.
What does it have to do with winds?
hi massive, in the videos on the knurling is used the propeller function to generate then the zigrination.
However, to what I understood I have to draw a zigrinating pattern on a sketch and then wrap it to the oval surface. I try and let you know what's coming out. thanks for the video on the grip of the pile.
I attach the zipped file to what I'm doing. It's made with sw2018.
Bye!
Mar
Obviously, being video on circular elements that method is what requires less resources.
the winding function however does not have to do with the propeller function, hence the question as a result of your statement:
? I missed your delucidations!
Anyway, I think I found the way. I tried with a circle pattern on an extension of the same oval perimeter. on one side remains a bit more space than the whole surface, but adjusting the shot should come well.
then I try with a reason to die like the zigrinature.
I'll get you the file if you want to take a look.
Hello, thank you!
m
