otrebor81
Hello, everyone! !
I write for help
I have to insert a zipper (or similar solution) to open a lid.
the problem is that the zipper must be internal and with a non-optimal fulcrum
yellow is the fixed part
while the other two components are solid: a sheet (where the zipper will be anchored) and a plastic, too weak for the hinge
plastic has to be external and this forces me to decentralize the hinge.
from outside (top) the system must be hidden
Thank you very much
I write for help
Thank you very much
