Hi, everybody, zooming all the design is very small and I can't find anything to erase as I can handle it? ?
He told me to cancel out leadership but how do you do it?
I'll give you an example of malfunction.
there is a rectangle, but the zoom extension does not work. using the double click on the mouse wheel, it becomes very small. It would be interesting to understand why and what the problem is.
copying the basic design on a new model, on the latter the problem does not manifest. the problem is that this procedure involves deletion of parts of the new model to replace them with the parts copied from the defective design, repeating several times copy with base point.
n.b.: the problem is located only on the zoom because all other commands and parts of the design work.
I immediately noticed that there is a white element at the top. It is a picture of about 400 side.
it was also enough to make a quick selection to realize that there are more entities than the only polylinea2d or more banally a ctrl+a ie selects everything that highlights all entities
Hell, it's not possible, I see it now.
I erased all dozens of times.
It's the perimeter of the ctr.
with ctrl+a found me the cutting points of the leaves, free of color and not selectable, I gave the ctrl+a and I deleted them. I didn't see the square, I erased everything and I did the test rectangle.
absurd. .
