Latest activity
  • Fabietto replied to the thread axis representation.
    Yes, to the reason we learned, but such sections are not voluntary. usually happens like this: sections something in the top floor and...
  • stevie replied to the thread tariff for plasma bench design.
    difficult to answer, the parameters to evaluate are different.
  • Peppe replied to the thread axis representation.
    I found this document see p.3 https://web.unica.it/unica/protected/283005/0/def/ref/mat264085/it's not exactly the same, maybe it's just...
    I don't know exactly if there are rules on this, but I have always reasoned like this: I put the axes I actually see in the...
    even if I
    I tried with inventor to dissect out axis and to insert the axes in automatic and being however a hole the software puts the axis, then...
    I would do a section by excluding the hole from the view.
  • Fulvio Romano replied to the thread electrogen group.
    There are two aspects for which I asked those questions. the first is that the vacuum regulator can not adjust well, so you have to put...
  • Unknown member reacted to meccanicamg's post in the thread electrogen group with Like Like.
    have you tried to remake the non vacuum measurement na with a constant load of 2-3kw? should auto adjust and increase the voltage with...
    the legislation previews that 95% of the effective voltage values calculated as average value in the first 10 minutes must be ±10%...
  • ceschi1959 replied to the thread tariff for plasma bench design.
    the fees applied by professionals take into account many factors, business risk, rents, employees, inail, inps and licenze cad legali...
  • jenuary replied to the thread remove custom properties from multiple files.
    hi allego the modified macro.
  • Peppe replied to the thread separate export cutting inventor.
    read this discussion https://www.cad3d.it/forum1/discussion/quantit%c3%a0-totale-of-parties.64335/
    writing on dedicated forums is certainly a wise advice, but just to understand, how are you measuring tension? Is it an empty voltage...
  • cad3d
    cad3d replied to the thread electrogen group.
    Hi. try to ask your question also on the forum electroyou, is a specific forum for the electrical/electronic sector.
