Latest activity
  • Unknown member reacted to SperX's post in the thread tool check vincoli with Like Like.
    on the bottom right there is the error icon double-click and isolate the wrong or over-defined constraints.for the bond grades that lack...
  • Peppe replied to the thread table in autocad.
    try to read this discussion...
  • Peppe replied to the thread exclude component from separate materials.
    Could be helpful to you this discussion https://www.cad3d.it/forum1/discussione/ricerca-ipt-come-nascosto.64470/
  • Unknown member reacted to batleo's post in the thread Inner diameter - external diameter with Like Like.
    Hi. ilogic rule is a good idea, but it seems a bit too much, I explain to me to click on the rule and activate it are more operation...
  • Peppe replied to the thread section. . ..
    with the bf section you "slapped" your set for which a half is non-existent. if from this try to dissect further with bg it is obvious...
  • Unknown member reacted to Cadinpiedi's post in the thread i ask for help with these ball bearings with Like Like.
    a tip for the thesis: improve punctuation. you need some more commas otherwise you risk the apnea.. .
  • davide75 replied to the thread mouse verticale, trackball o joystick.
    I used trivial vertical mouse like those of trust if not even under brands. for 3D modeling their work and I noticed improvements to the...
  • frankpi replied to the thread angle reference design.
    Good morning. I would leave reference to and position tolerance of holes diameter 5.3 I would refer it to this with a value of 0.05 the...
    Good morning, I don't usually intervene by limiting myself to read the discussions, I would still like to say two things on the table: -...
  • I don't know why one or both styles are created. you create the two styles in the pattern design, so you will always have them...
  • Unknown member reacted to MassiVonWeizen's post in the thread too heavy assemblies with Like Like.
    the parts of the toolbox, that is the official libraries of solidworks, it is better to abandon them; are heavy because full of...
  • Unknown member reacted to re_solidworks's post in the thread too heavy assemblies with Like Like.
    Hi, I created the vines and ignored the bookstores. my hexagonal screw, not even too simplified, weighs 80 kb. I have been working for...
  • creates two text styles with name as-quote e as-legenda using the fonts you want, if the program does not create them. if the expedient...
  • the fonts of created text styles are romans.shx and arial.ttf
  • yes, otherwise the variables of the old file remain in autocad memory.
