Latest activity
  • Unknown member reacted to re_solidworks's post in the thread how to elimino/hide blue lines from imported model? with Like Like.
    I usually avoid the faceted models like the plague, when I found them (made by others) and I came to have a full set, I had to eliminate...
  • Peppe replied to the thread back and forth lives.
    He did a rejoining test, I'll file you and tell us if we understand the problem. p.s. I made for convenience a single revolution
    can you post the native inventor file so as to evaluate the work you performed?
  • Unknown member reacted to reggio's post in the thread how to elimino/hide blue lines from imported model? with Like Like.
    . double strangeness... sent away the message without showing this message that I now see and that prevents me from sending without...
  • Didn't you get attached? must be a zip file to be able to attach it.
    roads can be multiple and depends on the result you want to get. if the radius is constant you can add the connection directly into the...
  • Can you share the model?
  • Fabietto replied to the thread tolerances for stagnated cap.
    from what I read, it has the shape of a float, but it is inserted inside the tube, in which flows the acid, and therefore it is...
    Okay, as I said. a curiosity. where are we? that you need precise measures to the cent, etc. the normal flowmeters I see around always...
    Hello, can I shoot you? and hypothesize to cover the magnet? maybe covered in titanium nitride? Okay, now don't shoot me.
  • MFT replied to the thread tolerances for stagnated cap.
    But if the magnet that I imagine can be a cylindrical pad, you can't incorporate it into the float by building it in two half and then...
    perfect was just a curiosity, since you never talked about size. I think that with 2.5 mm thick you have so little surface of support...
    just out of curiosity, but a koenig- expander cap isn't okay?
  • If I didn't get it wrong, a sldasm saved it in step and you opened the step always with solidworks, correct? I exclude problems with the...
  • Unknown member reacted to dieva's post in the thread force black print for entity not dalayer with Like Like.
    Yes, in every design. then when you're done with those files remove the macro
