size without limits, but nominal
  • Thread starter Thread starter fret
fret
hello to all, how do I set quotas directly with nominal value? I explain every time I insert a dimension, this appears with the limits, so I have to reset it from ownership in the field *value and tolerance > way tolerance* by removing the lyrics by entering the nominal.
in 3d environment you have to go to set up in the config (instruments > options) below tol_mode nominal instead of limit.
However, you should create a start part with your set config for your needs... if you are looking for the forum is a topic treated 100000 times... :wink:
p-h
First of all thank you for the answer and I apologize if I answer only now.
I work with version 2001, I tried as you told me but, it only works initially, that is to say that the change lasts as long as I work on the table concerned.
in fact if I close the session or simply the program and restart, everything comes back as before (quote with the value with the limits).
I looked at various posts related to this problem but I couldn't well figure out how to get this configuration by default.
you could please give me some suggestions on this so that you don't have to set the parameters at the face.
Thanks again
but save the configuration file?
is recalled in the config.pro?
Did you create start-parts?
Hi, I'm sorry if I'm late, but I don't know what, but how to create a start part, what should I do exactly?
I tried in the old discussions but I couldn't get the necessary information.
hello to everyone again, unfortunately I cannot find a solution to this problem of quotas... I repeat if please you could link me a post where this topic is concerned I would be grateful!
I am so sorry, it is not to be rude, but time is precious (and little) for everyone.
If you had lost a second to use the search button you would have solved it first, wouldn't you?
Anyway
http://www.cad3d.it/forum1/showthread.php?t=1155
hello and thank you for the answer, however as you have had the opportunity to read in my previous post I looked in the old discussions, but without a positive outcome, probably because I included as a search criterion words "not correct", if I had put *property model* probably would have gone better.
