series of performances
  • Thread starter Thread starter ias87
ias87
Hi! I would have a problem...someone could explain how I can perform the series of a protusion?
I attached an image..thank you!
select the "protrusion" side by side should highlight the serial command.
click it, in the menu that opens you have various options to run the series...
(Too simple... You know, there's some catch. )
p-h
eh si...:d... the hippo is in which type of reference to choose (direction, odds, curve...) and then how to set the series...;)...
I had tried to create a curve (circular) with a sketch... on which practically have to be the 6 protusions... I had therefore chosen "curva" and I had selected the sketch. .
and set the number 6...
However unfortunately the protusions are not on the curve but only the initial protusion is right (obviously). . .
So I wonder how I can do that?
excuse but is a cylinder the base of support of the protrusion to serialize?
Why don't you use "axis" option?
You can also use the "quota" option. . .
p-h
