genale Guest Jul 24, 2009 #1 hi I'm learning rhino these days.. how can I create 3d blocks like in autocad?
mariuss.r Guest Jul 24, 2009 #2 genale said: hi I'm learning rhino these days.. how can I create 3d blocks like in autocad? Click to expand... using rhino blocks is a two-part operation. 1) first you select all 3d/2d objects (...but also external files) that will constitute the block with the obvious command _block 2) then, to insert multiple times the block in the document, you use the command _insert I suggest you do some tests and read rhino's help which is quite clear on this command:
genale Guest Jul 24, 2009 #3 Thank you... I couldn't find the command!! It seemed trivial! ! ! curious what area of the Veneto are you?
mariuss.r Guest Jul 24, 2009 #4 genale said: Thank you... I couldn't find the command!! It seemed trivial! ! ! curious what area of the Veneto are you? Click to expand... eheheh for the series ...too simple because it is so:biggrin: province of treviso... but closer to low
