boolean operations
  • Thread starter Thread starter francis nerd
francis nerd
Hello everyone I am new to blog language
So I made another excuse.
cmq about my problem I own rhinoceros with its plug-in and also magic
but I need a software ke let me do bolean subtractions of mass or ke speed me a little time.
I work in the gold industry.
and I do pre-cutting to the pc.
then go many solids to make the difference with rings etc.
I need a practical and functional thing also a rhino plug-in for boolean. Would you help me?
Hi, I'm just learning rhino, but I can't understand your message, so you don't have enough bolean rhino commands?
Of course it's enough
I have a magic program
if you use a little rhino
then you will start using it
for prototyping.
cm2
Concerning my problem there are ke surfaces I use ke need boleane fuotri subtractions from the commune.
and I need something to speed up time.
If you have any ideas...
then kiedimi anke all that ke ti va sn quite expert
Unfortunately being recently in the field of modeling I have no useful advice to give you!!! I'm sorry!
It seems to me that there is a bit of confusion, to me they have taught that the bolean subtractions can be made only between solids and not between surfaces, then that they can do it is another speech but the result is not always ugale to itself, you have to go a little for attempts.
I still don't understand your request for help, don't you know how they work? Do you need anything in particular? Maybe you put some pictures with the problem. .
So... .
I'm sorry if I was kiaro
cmq...
the subtraction takes place between 2 solids.
1 basic
and many others.
the basic solid as the subtractions happen
makes the rhino or magic file too heavy
slow and very often turns me solid into wireframe... I need something that increases the speed of Boolean subtractions
this file already has all the bolean grooves
nn poxo put the files 3dm perke the company nn allows it... .
thanks for the answers
Okay, now I understand your problem,
I think there's one thing to do: change computers.. .
If you have objects like the image I don't see any other solutions.
I worked with a file similar to yours (lucky happens 1-2 a year) and I had the same problem.
even with other softwers the thing does not change, the amount of surfaces/solids you have to manage for your works are many and consequently also the weight of the file and the accounts that the pc has to do.
What kind of car do you use?
I have an xp 3 giga of memory.
and these works for me are on the agenda.
I've always asked. ...
I know more ke fish to take.
above all I need a plug-in ke give me the possibility to place throughout a surface of objects
you know something.. .
I know that of you the pui full of problems I...
Don't think, I have my cats to peel too! !
3 gb ram?
video card? I hope a nvidia picture fx580 or higher
to place on a whole object surface
and dispoli at equal distance there are the "series" commands of rhino, did you try them?
n-vidia 121.4
I've tried it.
but I need something that gives me the chance to click on a surface and a circle or an object and that it automatically and equidisposes it from each other on the whole surface.
cm2
We're here.
Tell me about skede video
I need it.
for our work
What do you recommend? ?
if it can be more useful in the case of spease.
in addition to the graphics card you must also see what machine you have under.
I've had a lenovo's s10 thinktation for almost a year.
http://www.pc.ibm.com/it/thinkstation/thinkstation.htmlwith a nvidia picture fx1700 and I feel good to manage files with even 5000 surfaces
now has exit the new tab fx1800
http://www.nvidia.it/object/product_quadro_fx_1800_it.htmlthe tapered grip was not indifferent but it was worth it.
I can keep 2 cams in calculation and 4 rhinoceros sessions working on the 5th without problems
Oh... really thank you
You can imagine how much you helped me. .
Can you tell me how much memory you need?
What do you do?
on my pc I put 4 gb of ram with win view pro to 64bit
I make small sized models and prototypes (100mm x 100mm ) large size (4600mm x 2600mm) through cnc milling and I happen very complex design such as, for example, a 1.6mt x 1.6mt ball or ultralight fuselage com several thousand surfaces that I often have to change for production needs
Great.
I produce pre-incassed models.
We're the only ones worth doing stuff.
anke if and a stress the results keep alive my desire to design. . .
I work on models more or less of the same complexity, but at the cost of losing hair I always tend to trim the surfaces and not use the boolean operators. In this way the model does not weigh and the quality of the intersection remains high.
What do you mean to trim me? . .
I am of the opinion that you must listen before I reply I listen... .
I don't know what that means....
I could use it.
the basic operation in working with surfaces (e.g. nurbs) is the trim.
if you intersect two surfaces you get a curve. you can remove from the surfaces the part bordered by the curve.
the trim is a generalization of the Boolean operators. more than a command can be considered a macro. a cut on a surface made with a boolean is equivalent to a trim. then the trim is faster is all another question:wink:
