special automatic bubble
  • Thread starter Thread starter pietro1
pietro1
Hello,
it is possible with inventor 11 prof. to recall the bubble of the particular inserted in the cart.
I hope I've been clear.
In fact I have a view in the cartiglio together with the bubble of all details.
In the same view I have the details and I would like that, instead of manually inserting the call to the bubble of the view together, this happened automatically.
I hope I explained.
I hope I explained.
You've made a basic view of the total and you've stacked it.
on the same format you have entered other basic views of the details constituting the total and you would like these to have the same reference number applied in the total.
I'm afraid that's impossible.
I have not seen the table of rel. 2010 but in 2009 there is no automatism.
of the rest every basic view makes history to itself.
I think the only way could be this:
from the basic view of the total you make a projected view and, in this, you leave only the detail that interests you.
from this view project the others you need to quote the piece.
proceed with all the details.
It works, but I think it's not worth it.
other thing:
the cartilage is only the box (which usually puts down dx) with code, description, material, scale, etc.... What you're describing is a table.
I didn't know, I knew you could do it from a section but not from a projected view.
Can you explain how?
This "problem" I have it constantly. . This happens, because every component of our set (saved) is not attached a building table so a code, so either you do as it says stefanobruno, but it takes time to remove the visibility of objects that you do not care to see etc.... or the reference is written by hand....
or if your is a welded set, when you insert the view - model status - in preparation you select the part you want to see....... Unfortunately it does not work if you want to fly the flat pattern of sheeting
go to the projected view --> button dx --> located in the browser --> in the tree of the parts selections all except the element you want to remain visible and remove the tick to the visibility.
from them forward, in the views generated daughters you will see only what is visible in the view mother.
then also find the items you want to make invisible directly by touching them in the window but you have to change the type of selection priority (from edges and lines in priority part) without going through the browser
OK, thank you, it works except with additional projected assonometric views.
a clarification again:
in some idw, making the various passages, when I get to the voice of visibility, this is not tickable, it appears grey clear then denied.
How come?
How come?
the main view is in "associative" or is always updated with the various representations of the axieme.. .
depends on how the visibility of the mother view is set, the derived view follows the visibility settings
