copy
  • Thread starter Thread starter mascla
mascla
copy of the properties of this part on another part that only changes the code as you do without the bacth
select all rows as you would with excel and then ctrl+c. go to the other side and highlight the first blank row and then ctrl+v. you copy only the first porpriety, then you place with the pointer on the cell of the glued value and send. ongi time you go to head paste the line below... I don't know if it's clear.
but I have to copy only those in the value field and not select them as I do?
copy the whole line from the property name.
you must select the column of numbered "pulsants" on the left; Click on the first at the top and drag down to the last at the bottom. all lines are blackened and do ctrl+c.
but when you copy a part you take after all the properties, I don't understand your need.. Did you remodel another one just to change the code?
I'll explain to you that I have to collect furniture many fields remain unchanged sometimes I should copy only the values of what remains unchanged but I would like to do it all together once I think there was a text file... but maybe I'm wrong
the text file offers you in the drop down menu the property names, but does not fill the values.
then it seems that you cannot do this
Well...
Maybe I didn't understand what you mean, but I think the solutions are there. clearly you cannot expect the program to interpret your thinking by compiling fields that are still variable.
the text file you refer to is the properties.txt and that there is always, but as said "automatizes" only the names of the properties the values are you who decide them (and who else should? ).
However, if you have many equal "almost" components that differ only for a couple of entries you can create part templates with the already fully compiled property card except in those 2 variable fields. when you open a new check that pattern and you have much of the compilation work already done.
better yet if they actually differ only for the code and maybe this code is equal to the file name; in this case you do absolutely nothing because you already have the fully automated property card in the model. the description if needed you can also give it in the save screen in the appropriate line below.
if the problem is another one maybe explain it better than maybe you get there (post a couple of sample files).
Marco:smile:
Wait. .
but then copy with ctrl only the lines you need.. or do I still not understand? ?
if the properties are scattered do first to rewrite them by hand. If you want some proposed property "values" you need to use "tab builder", make yourself a compilation card and during the configuration of tab builder you can put some suggested answers. to do so you have to enter the drop-down menu leaving manual writing possible.
