gioz86
Hey, I've been working with rhino, but I can't say an expert. .
I managed to create a surface through the union of various other surfaces but trying to make it solid even through Boolean operations tells me punctually: Boolean operation failed.. .
the operation I'm using is "crea solid" and tells me it's impossible....
if I go to diagnostics-->verification tells me "no valid rhino surface object" and then gives me this:
"distance from end of on_brep.m_t[1] you 3d edge is 0.0196882. (edge tol=1e^-0.5 trim tol=0)
....that is a problem of tolerance?
Can you tell me maybe an alternative to make it solid, or maybe how can I try to do I'm blessed solid plz?
Thank you so much!!
Thank you so much!!
