marcocad
Hi guys, provided I use the 2010 version, I have a solid display problem with curved shapes. I usually draw in meters and realize that lately all shapes with small dimensions give me problems. going to zum any curved shape, you notice the space between the object filling and isolinea (i.e. the design background), especially if the dimensions are small on a measuring unit in meters. you will tell me draw in mm, of course the situation improves but when I have to climb everything to insert it in a drawing in meters and how it drew in meters. I was wondering if you can help me solve this problem since I probably think it's about video card settings. (the facetres variable even at most does not help me so much). I attach an image of a simple 4 cm diameter cylinder and 5 mm high (the size of a gommino for a sofa to draw) to understand what I mean. you will notice the difference between the wireframe view and the other...my goal is to visify objects with realistic shading with the properties of "rotondity" of the wireframe...
thanks guys:smile:
thanks guys:smile:
