detailed sheet view
  • Thread starter Thread starter lustro
lustro
I used the "search", but I found nothing, I hope nn to make a double discussion:redface:
my problem is with the table of plates in sw2008 (but it seems to me that the same inconvenience there is also in 2009).
then, I realize the 3d of the sheet piece and then I go to put it on the table; with the orthogonal views all ok, the problem arises when I put the development: If by chance when I insert it I have to rotate it (e.g. for reasons of space on the sheet) and then I have to make a detailed view the program goes in crisis: : the detail view, as a position on the view, is referred to the default view that would provide the program (the rotated one), and the beautiful is that however the detail is seen rotated.
I hope that the explanation is understood, but above all that someone can explain to me how to refer detail to the rotated view, so that they see the right details: nn I think it's easy when you make the 3d of a sheet think about how it will be development and in what kind of sheet I will have to put it........ :eek:
Can you tell me, please, version and service pack? can you post a file? I think it works correctly (swx 2009 sp. 4.1).
Who do you mean? ? ?
in the annex you can see the window of the sw version
last week I tried for a day sw2009 (I remember the service pack) and I think it had the same problem
thanks to the indication marco :finger:
now I put you the 3d and the table
and I hope they are useful to solve the problem...
Okay, but where's the file?:confused:
I don't understand your problem anyway, because it doesn't happen to me. I can turn my father's view as I want but that relative detail not from problems. now with swx 2009 sp4.01 but I have always done it since 2007 (but I jumped 2008).
maybe you should explain how you make the sheet, how you get the development, how you roote the view at the table and how you do the vista dettagliata (.. too many requests?:biggrin:); Maybe it's a procedural mistake.
I also with 2009 sp. 4.1 I tried and fled correctly. in my opinion may be:
1- a kiss. 0.0 service packs are always full of bugs and it is known that each version begins to become stable from sp. 2
2- a problem related to user settings. in that case you should enter the logs, back up the hkey_current_user->solidworks folder, then delete the folder and restart swx (at this point is without settings) and try again. if the problem is solved is related to a registry key, otherwise you can close swx, double-click the backup file created to restore previous user settings.
3- a process problem, but I should see a file and have a meticulous description of the operations you do to understand where the problem might be hiding.
I'm sorry, but I don't know why he uploaded my file. It's a 300k .rar. .
Now I try again....... and I managed it! ! !
I made it with normal sheet metal controls, flange edge extrusion....the basic controls, nn seemed to have used strange things. .
for the table I followed the sw steps, in the file there are only the flat repetitions (development) because they are those in which the probelma occurs: the one above is positioned as the by sw and nn I have problem in the views of detail, the one below instead has been rotated of 90° and as you can see the view of detail nn corresponds to the detail circled on the view father
tried with 2008 sp0.0 works correctly.
in the design view 6 I brought the rotation to 0° and then again to 90° and everything has adjusted
I have your luck
if I rotate the view 6, that of detail (c) continues to "point" on the rectangular excavation and not on the other; when the roote the only thing he does is put the rectangle vertically.....
Lucky people like me who found a solution??? Please...
Perhaps I have found how to solve (in a proper orthodox way) my problem.
reading the sw2006 training manual, I found where it explains how to rotate drawing views based on the edges: If they select a vertical edge and then I tell them to align it in horizontal, I turn my view, and the reference for the detail view remains just :finger:
I hope it will be helpful to others too:
I am already happy because I solved the problem :biggrin::biggrin:!!!
