shared view wf4
  • Thread starter Thread starter rubo825
rubo825
I have a problem with wf4... in the split views I can't put the odds... on the wf3 you know that to quote split views you don't have to select the axes, but only the edges of the geometry (at least the version I used was so), while on the wf4 I just can't!!!! help....:confused:
no that should do it! that I know the pro-and problem about the split views is only with the axes, the rest the quota.
but did you try with the exhibition and delete to pull out the patterns?
I confirm that said by prof. , recalls in the drawing the quotas of the model. I recommend always doing it, even if the view is not split so you can change the model directly by changing the odds in the table.
