[draft] reconnect angle odds
cacciatorino
sometimes it happens that the odds in draft disconnect following updates (typical case: the new table comes from an old whose model of origin is the mirror copy of the reference model of the new table).
for the linear, diametric and radial quotas there are no problems, just move the reference line on the new edge and solid edge reconnects the quota.
but for angles? Is there a way or should the quota be erased and restored?
The reconnection of angular quotas should work the same way as the others, at least I do not have any problems.
try to hold alt when identifying the reference line, this should force if to abandon the connection to previous references and to hook up to the "new" line
I don't think they're reconnecting.... I tried, doing them every time.
They're almost never connected to me, but now I've been able to do it with one, but it's got me the complementary corner. ...
I did some tests and in fact I have difficulty reconnecting without holding the alt key, if I do it instead I can without problems.
the quotation of if it sucks!!!! I have already reported to the assistance time ago that the quotas disconnect even without reason and if then reconnect them holding alt sometimes takes them not...and they are more not.
You don't understand why you do a parallelepipedo and make him bevels.
and then between one face and another, if at the end you suppress or delete the bevel feature also disconnects the quota, while having selected the face.
with the st these problems among other things have increased!!!!! more than 100 times faster.
report it to the assistance also you this problem
