problems with print pdf3d
  • Thread starter Thread starter fabrizio_brescia
fabrizio_brescia
Hello everyone, I was experiencing the output of wf4 towards the printing of docuemnti pdf 3d.
In fact, ptc saves a file that is not read correctly by acrobat.
I noticed that this problem arises together with many components.
Can anyone tell me if there's any kiss in this export or if you have to do it in any particular way?
but how many components do we talk about? what is the file that is not read? proe passes by a file with u3d extension before you pdf, you mean this?
However, you should look at the std.out file that is created in your work directory or the proe starting directory: if you find messages like "memory allocation failed" means that the axieme already has enough memory; The export operation requires more by crashing proes.
you can try to export a simplified representation.
components are those of an electronic card imported with ecad, so we talk about a set of about 600 components plus a board on which they are bound (top and bottom).
the components are different types, besides there are several times the same part there is however a variety of parts (about 100 different).
wf4 has the direct exit to pdf3d, so you do not pass through conversors or other.
In fact on simple systems the thing works, (kitchens of components) but on heavier assemblies when I go to read the pdf generate shadows and you can not rotate the asses etc.
in case I have to go out with the u3d what do I have to do to convert it to pdf3d?
What version of wf4 do you have?
I with the date code m100 and
total of the parts contained in the axieme 31kp1100156 :344
and with
total of the parts contained in the axieme 31kp1100142 :738
I had no problem.
I take advantage of it to ask having I also acrobat distiller known the possibility to do section and take some measure. on another pc where there is only the reader these two possibilities are not there, do you confirm that they are the prerogatives of the distiller?
