feature in visi 16
  • Thread starter Thread starter endrio1
endrio1
Hello everyone I was wondering if someone was able to recommend me the fastest way to perform work on multiple tilted holes of the same type arranged on different cam setup without having to be forced to edit every single operation, every single tool and all the cutting parameters.
ps. with 24+24+24 male holes and not arranged to different inclinations no longer passes me.
Thank you all.
Bye. I know that when you need to edit holes, visi 16 can edit them by categories, in cases where they have common characteristics. So you do a lot earlier. but what edition do you have? ? because if it's not the most recent you can still find a few boxes that don't allow you to work automatically.
Bye!
hi, for what about the version I have everything updated to the last available patch of the 16 waiting for it to be commercialized the 17.
Would you mind blowing me out better what you mean by editing by categories?
Thank you very much.
hi, if I don't remember badly...if you have a set of holes, for example 4 of diameter 5, 4 of 6, 4 of 7 the cam when you make a drilling cycle you divide them according to the diameter and then you can editate them in 3 operations. idem if it's depth, etc. I hope I've given you help. I saw this operation at the update course and I don't remember using it anymore. Hello, good day.
hi layer1985 I'm sorry but I didn't understand what you meant anyway I solved the problem with version 17 in which you can now duplicate a operation on cam setup different keeping them tied together so you can change n operations equal on n cam setup different in one shot only.
less bad because before it was crazy to think of going to change one to one all the operations.
Hello and thank you.
:finger:
:finger:
but is already available 17?
I've had it for a week.
ps. It is not that it changes much from what I could see.something has been improved but the most interesting novelty for me (an incremental hub) is still in the embryonic state.
