ground binding
  • Thread starter Thread starter acasali
acasali
Good morning to all, I ask something maybe stupid, but it's hardly that I started using thinkdesign. how do you bind a solid to the ground, so that it is fixed forever?
thanks to all and good work
alessandro
Are you talking about blocking an object in the axieme? . . .
explained better!. . : )
If I understood your question... you should bind the first with a positioning bond, I never bind them but I think you can do.. every tant I use the vinsoli to assimilate more objects. .
alessandro
explain to me, do you want to tie a profile or do you want to bind a solid to the ground? What is your goal, that is, why don't you move?
alex
thanks for the answers, but from what I understood it is not possible, in td, "to lay down" a component/solid. in inventor, at the same time, there is a simple command from the right mouse button: "fixed."
I simply wanted to block in space a solid that simulated the ground, on which I then supported everything else.
to the next
alessandro
to the next
alessandro
Well, I believe that the same gets created a solid that will be your soil and bind others to the latter or to other solids bound to it. Plus this way you can also move the solid land where you want if you don't like it. remember that there is also multiple positioning.
alex
