The Sheet
  • Thread starter Thread starter maury_m
maury_m
Hello everyone
I have been using sheetmetal for 18 years and not until offi.
I was asked to develop some extremely simple figures.
but I'm not completely satisfied, and I'll explain why:
the sheet a question is a simple extrusion (see images)
making ublend the development remains uncentred on the plans.
How can I achieve the unblend correctly, that is, by having the symmetry as a fixed point?
I don't know if you can do as you ask.
When you use the flat series, you still need a flat surface or in the absence (as in your case) a corner from which to develop geometry.
it is possible to resort to tricks, making for example a flat part near the half-axis but, I avoid them.
I could not make a flat part because the component is aesthetic
I should do a cut to eliminate the problem.
This other component has no straight edge: I developed it with the "flatten quilt" command but I don't know how reliable it is.
thanks for the help
maury
the function you use from the developments in a correct way only that you have to use it by paying attention to the factor k of the material (although in your case the "folding" rays are very wide and therefore should not give you any problem).
I hook up: where does the K factor set? I looked at it and so I didn't find it.
good morning to all and compliments for the site is exceptional
I would have a similar problem, I would like to displace the attached profile
and get its development plan, can someone help me?
thanks max the film is fantastic
the profile I had attached was made +o- so
But wanting him to turn away?
If you have to displace the piece, the development remains that of the straight piece.
If you need to draw the piece, take a sweep.
in practice scroll through the section along the axis, which will in this case be a circumference arc.
I tried with the sweep and with the command of revolution
but in both cases it does not allow me to make the folds
What? I attach the profile
you can't develop the piece.
you have to make two different models (one straight and the other calandrato) or try with the warp (svergola) I don't remember though if it works on the sheet metal parts.
