Piccoloingegnere
Excuse me only 1 second... who ever talked about processing a diesel or getting it to 6000 laps?It was a long time that I was missing in this forum, fortunately 5 minutes ago I felt like taking a trip around here, and less bad than I did, dear little engineer, you're making me die, not only laughs, but also fear.... okok laughs perhaps is too much, it is not nice to laugh at who is driven by strong passion like you, we say I smile so much for your unbridled enthusiasm, and for your conviction of being able to process a 4 diesel times by adopting lines of principle. The fear arises from the fact that despite everyone trying to stop you to reflect, you continue to hunt new innovative solutions, you seem like a computer that is performing a routine.... .
Stop! !
I don't work in the automotive field, but I understand enough, both because at 17 I used to be a madman on the engines, as I think you do now, and because I had the opportunity to study them also from the thermofluidonic point of view.
the design then, is still another thing, and that we want, as far as the engines are almost entirely designed to the computer, by a team of expert designers and analysts under the guidance of very experienced motorists (experience at the counter) then after they are put on the bench, they never go like the last evolution of the previous engine, but it is practically the norm that they go worse. at the bench the motorists experts who guided the designers and analysts in the design of the engine, will have their nice to do with the tuning that takes time comparable to the design time, yet they have designed it.
to tell you what? that the engine is not an exact science, and it is rich in unknown even for those who have been working for 20 years, let alone for a 17 who can not listen (or read ) who tries to take it on the path of reason, so do not leave it saccentemente with a splinter of inventions one behind the other if you want to get something, so you will only make you many enemies, or at least, you will know very few people (one?) willing.
I suggest you focus on one aspect at a time, one... .
Anyway, and here someone will punch me definitely, the diesels just elaorate raising the pressure of the turbine, compatibly with the mechanical and thermal resistance of the various components. there is little more to process, you can't make it turn wonder how much faster, because the oil needs its time to burn, which is greater than that of the gasoline because the gasoline air mixture is heterogeneous, and this must evaporate in the room, and the diesel is less volatile than the gasoline, so the rotation speed practically imposes it in the first place the fuel, then the average speed of the piston.
retouch the valves is a waste of time, because the engine is slow, you do not have big problems of load losses in the valves, increase the diameter means to change the shape of the room that for a diesel is much more delicate than for a gasoline, change the diagram means to look for a coupling to a higher regimen, but you can hardly reach it (of course someone has reached the 6000 with a jtd but it was an intense but short emotion)
read a nice book about the engines of non-academic ones, clear your ideas and then focus on one aspect at a time.
