standard parts incorrect db version on st2
  • Thread starter Thread starter Leso
Leso
ahi ahi ahi...
I don't understand that.
I installed the st2 and its administrator for standard parts.
with the 20 and with the st I had created a custom db with my parts.
Now it no longer allows me to use that db! tells me that the version is not correct! What the...
ahi ahi ahi...
communicate it on the American forum, developers are very attentive to the feedback of the first users.
ahi ahi ahi...
the same thing happened to me when I replaced the ws, I was never able to make the standard parts work.
the error that gives me when I try to open it is "this version of the cad system is not supported. please contact your administrator", is it the same for you too?
There is a document (see Annex) that provides guidance to solve the problem, but with me it did not work.
If you can fix it, let me know how, you never know, maybe the solution that's okay with you is okay with me.
no error is different: tells me that the db version is not correct, not that of the cad.
I'm the one with my updates. I'll never learn.
from the American forum:
to use solid edge st2 standard parts, solid edge st and earlier standard parts databases are not compatible and must replaced.
I had to rebuild the db. what in itself not particularly complicated nor long but...serious.
I hope for you that it is possible to go back!
No no I eventually converted.
the db works, I can draw hexagons without macro and... there is a beautiful green key useless to close the sketches.. .
always and still pioneer;-)
bwhahahahaha!
cmq I'll be stupid but I don't really understand what that key is... it's a double of another just put on another side. Mah!
