psm: tub with folds of different angles.
  • Thread starter Thread starter Cast16
Cast16
How can I develop this?
I also tried starting from birth but nothing.
aurel
is developable unless the lembi are surmounted.
They don't get over it.
sends the psm (not the par that is not developable! ! ! )
I sent the file.
I managed to develop it. but avolte I can't understand how ray if:
- before I dig6 doesn't make me convert sheet.
- I'll dig 6.
-converted sheet metal ok
- I'll dig 6.
-mi maintains the conversion into sheet metal and the developed field:eek:
I don't know how to do it. . .
Thank you all.
version of the file? ? ? ?
I can't fix it with 20.
anyway I would do:
- the base flap
- a multiple flap
- end
I sent the file.
- I'll dig 6.
- I'll dig 6.
Thank you all.
see if the point can be useful.
test starting from the multiple flap drawing the "section" with the two different angles....
I don't understand...:confused:
I design the base flap and then a multiple flap running along the edge: To do it as you say, I should at least make two multiple lembies.
only solution?
