save as 3d data - 3d changes....what do you need? ?
  • Thread starter Thread starter EMA82
EMA82
Hello, I just discovered the command on the vs 14 saves 3d data and saves 3d changes ...who uses it I know' explain what advantages involve !!!
thank you all!!!!!
thank you all!!!!!
in principle to save each part in a separate file instead of making a pkg of the whole axieme. However, it's usually a work mode not recommended by cocreated technicians.
thank you all!!!!!
serve as the breathing air!
:smile:
If you use the edit_3d you can consider yourself an osd user, otherwise use pkgs and please "commercials".
:smile:
first you have to learn how to use ids.
If you can understand what they are and what they need and how to use them you are halfway through the work.
Id is the "serial number" of the model, each model an id, an id a model.
regardless of name.
the name of the part is superstructure, fuffe, useless smoke balzello, pretend that it does not exist, let osd to give the name that it seems to the part (p1, p2, sacred crown united) does not matter.
It is essential to declare the id that the dna will be the mark on fire of every part and of all its sharing, everywhere on the planet, the unique code that will identify the part wherever you will save it.
tomorrow we go ahead, while you learn to work with the extended browser, which always shows the id (the so called "content part").
night
when one has a new blank part (p1) without id, osd cares to create one automatically that coincides with the name, so much to write in something.
created the part and given him a congruo id this part begins his race.
What does it mean to share a part?
means creating a link, a pointer pointing to the part, so a shared part is a "ectoplasty projection" of the original part, it is not a physical copy is a simple vector.
the fundamental fact to understand deeply and serene is that, in fact, the part, the starting model is a link placed in the "root" of the starting aid.
when I open an empty osd, I am "inside" an empty set placed in the root, I build my part (the "crea"), osd creates a part in memory and immediately creates a link in my set (root).
so I always see and only a pointer, when I get the "active" part, I access the memory portion that represents it.
the link (my representation in my root set) how does it reach the location in memory? through the id, which identifies it.
Therefore, first step, the id identifies the location of memory (univoc) that represents the part, the name is simply the name (please) that I give to the link in my set.
but excuse president what you call id is the model name that appears in the properties of the part? I this details button dx in your browser just can't find it
If you have one of the latest versions, near the name of the browser window (you should call it "fvista" something), there is a kind of icon, type electronic sheet, click on and expand the details, the id is what is under the column "model name".
our president a slightly dated version of modeling:smile:, in the last versions searched up to sx , just above the list of the parts, there is an icon, if you put on it comes out the written details and if you click it appears the list parts with details, the column name model is equivalent to what you kimate id (volgarmente known as code), that will become the name of the file in saving data
I don't understand. .
the model name I give it, and unique for all shared parts.
the id that generates osd is of the type 513000-984767269-80ad8dc645-0 1965162.
Now, I clicked on the icon, but it just puts me the model name and not the id...
where I can click to highlight the id, with the dx button nothing comes out.
I forgot I used 16.50.
Michael
who formed the cad did not even do training?
I use the 3d save because I can reuse all models quickly.
together with our supplier we built a folder structure to use the 3d save commands and 3d changes well.
Hello everyone
Hello everyone
if you explain how you make a folder structure since the *.sd modeling part containing the instance does not link the parts contained in other folders but must be all within a single folder...... .
Hello everyone
modeling not only loads files that are inside a single folder, uses search paths as for customization files.
management of the "folder structure" is done manually is this the big modeling limit. There is a workbook where you store the templates you are planning, in other folders you store the finished models.
the passage to the pdm becomes almost indispensable.
Hello everyone
That is not the case.
if you want to work well, take a pdm, even light, as you know I use the cdm products, and with their new pdm (which finally have done) you work well and there are no plasters, files shared with all and controlled so as not to mess with others!
