problem slow copy-paste from one file to another
  • Thread starter Thread starter grillomaltese
grillomaltese
Bye, guys.
I introduce myself first of all:I am grillomaltese, not so young user of autocad/adt2008 for more than 15 years. I used to have fun with another sw cad on unix platform, sw now dead and buried.
the reason that brings me here is to try to solve some problems affecting my file billboard in dwg format. Here's the facts. my working group manages the design of a large company. our 350k square meters are completely censused and inserted on files. a section (specifically the files regarding a building of some floors) give us some time of the thread to twist. I explain better: to make a copy and paste from one file to another even of a simple rectangle or text of two words, it makes us lose even 15/20 minutes (if all right). files are structured with different layers (we noticed that some of them have $0$ string in their name). There are countless purges and verifications made to these files, but without result.
Could you help me out? ? ?
Such problems are classic of an excess of layer filters or unnecessary annotation scales.
the problem has already been dealt with in other discussions here.
I refer you to the links where you can find the application for the removal of the superfluous (which does not happen naturally through the purge command).
http://www.cad3d.it/forum1/showthread.php?t=2032
http://www.cad3d.it/forum1/showthread.php?t=1664
Thanks planner road,
I'll let you know how it went. Thanks again
these two links lead to two other Czechs (ex Czechoslovakia). I don't know what to download.....:confused: I don't speak Czech!
download programs instructions are in English!
in any case you can still use the two applications of the autodesk itself, which are always reported in those posts.
I found and downloaded the Czech site better purgeids. after decompressing the file I find a lot of files but there are no executable or similar files. What to do? ?
I had thought about it but this message is returned to me:
also in this case, what to do:biggrin:
There is a readme file where the instructions are given, if you have problems after reading it lets you know.
as I told you above you can also try with the two autodesk applications that are always reported in those discussions.
because you are trying to install the 2010 autocad version. the r.18 is that of autocad 2010.
download the one for autocad 2007-2008, which is yours.
Hey, guys.
Also today I return to cad3d.it to understand how to solve the problem that stands at the top of this thread.
plannerroad has shown me some links from which to download some sw that should solve the difficulties I encounter. from the Czech site I get only the useful sw for autocad2010 and not 2008. where do I find the one suitable for the older truth? ? ?
Hey, guys.
If you had read the readme file of purgeids, you would have found this written:
to run in autocad 2007 to 2008, load the purgeidsr17.vlx file with appload
in that folder you find the file purgeidsr17.vlx for your version.
instead, regarding the cleaning of the excess annotation stairs, also for that program (scale list cleanup utility) There's the 2008 version you need.
http://www.cad3d.it/forum1/showpost.php?p=33130&postcount=2
