quota minimines
  • Thread starter Thread starter Mauri:66
Mauri:66
often happens that in wanting to quote a minimum angle (0.5° - 1st) in the technical table through the manual quotation with entities, I am quoted the diameter rather than the distance.
without going to use automatic quotation, is there a parameter to set?
Thank you
Thank you
automatic quotation has its own logic and depends on the exact point of the line in which you go to click!
try zooming more than you can the area you need to quote, click about half the line you need to quote and see if it makes you the corner... .
Let us know
thanks for the answers,
but for some reason can't I attach any images??? ... however while zooming and repeating the quotation in several points by selecting the two entities (not parallel) ...picche.
It is simply a question of quotating a corner between two straights not parallel but distorted about 1st.
if that angle exceeds 1st, then the system will quote it correctly.
I just did some evidence and reiterate what I said before.
I'm listed on where I'm positioned with the click.
post a dxf if you want me to try (even only of the 2 rows to quote)
Believe me I can't attach any files even if very light,
Try to make a sketch of revolution that results in a simple form of glass.
the inside of the glass must have a sform of 0.5°.
do a section view on the technical table and try to quote that angle through the selection of the two entities and see how the vs. program behaves.
At this point you do this:
increase the grades in 3d, go to the table, quoti, go back to 3d, put the right degrees, regenerate the 2d and you find your right angle.
ok mali_fx, the problem so is radiated but this involves regeneration even of more than 1000 features and then the regeneration of the table you believe is not always light, multiplies this by x_volte ....:eek:
but do you behave like that?
problem solved!
There is the setting in the config ''minimum_angle_dimension'', if you want me to tell you a less than 0.5 angle you have to set 0.4 or less.
also to and often happens to doer make odds of angles 0.5-1° (forms... )
I try to zoom a lot, then I try to touch the lines in the middle, then I try to put the arrow of the pointer right in the center of the arc formed by the two lines and place the quota.
Unfortunately it's not always easy, I know, and it takes a few tries.
I often help by creating a line of support with wax line from the quotation menu.
