create new cartilage
  • Thread starter Thread starter Bo.Ma.
Bo.Ma.
Hello everyone, we have purchased the think3 cad for a few months as a cam support cad. Now we have the need to perform mechanical components drawings and I would like to know how you can change or create a custom cartilage according to our needs, without having to manually modify the standard cart.
Thank you in advance for your collaboration
bo.ma.
bo.ma.
from table 2d model you find two commands; "Save as a board team" and "Save as a cartilage". the online manual explains the procedure, however rather simple :finger:
thanks for the quick answer.
Unfortunately the online manual is in English.
e' vero, quella parte del manuale non è ancora in italiano
comunque questa è la procedura
to create a customized drawing frame, proceed as follows.
1 start the think3 application and get ready to create your drawing frame. you are enable to:
start a new drawing in order to start from scratch
open one of the application default drawing frames in order to start from a sample
open an existing customized drawing frame if you need to make a small change to it or if you need to create a new drawing frame similar to an existing one
2 draw or edit the geometry of the drawing frame. make sure that the lower left corner of the bounding box is in the work plane origin.
3 save the drawing frame with the save as drawing frame command. when you do, pay attention to the following:
the drawing frame description is the information displayed by the think3 application when you actually insert the drawing frame and it will help you select the one you need. keep it short and clear. avoid indicating size and orientation which are already used by the program to filter the drawing frames names.
when you select the title block anchor point, snap to one of the four corners of the drawing frame. although you are enabled to snap any point in the frame, the results may be unpredictable.
the program inserts a point at the title block anchor point. it will automatically remove this point when you actually insert the title block.
the program will display the new drawing frame description in the relevant drop-down list of the drawing frame and title block command, provided that you have selected the corresponding size and orientation.
4 in order to verify your work, start a new drawing and use the drawing frame and title block command to insert the new drawing frame.
per la squadratura è importante il punto n°2 ovvero l'origine del piano di lavoro; per il resto è sufficiente salvare il modello della squadratura con l'apposito comando.; idem per il cartiglio
to create a custom frame design, proceed as follows.
1 start the think3 application and ready to create the design frame. six allow:
start a new design, in order to start from scratch
open one of the default ironing applications so starting from a sample
open an existing custom frame design, if you need to make a small change to it or if you need to create a new drawing frame similar to an existing one
2 draw or change the geometry of the frame drawing. Make sure that the bottom left corner of the selection rectangle is in the original air work.
3 save the frame drawing with the save as frame command design. when performing, pay attention to the following:
the frame design description is the information displayed through the think3 application actually when inserting the frame design and will help you select the desired one. keep it short and clear. avoid indicating the size and orientation, which are already used by the program to filter the frames name design.
when selecting the title block anchor point, snap to one of the four corners of the drawing frame. even if you are able to snap at any point of the frame, the results can be unpredictable.
the program inserts a point in the block anchoring point of the title. will automatically remove this point, when you actually insert the title block.
the program will show the new frame design description in the relevant frame design drop-down menu and the block command title, provided the corresponding size and orientation has been selected.
4 in order to verify your work, start a new design and use frame design and block command title to insert the new design frame.
so translate google
excuse me I use a 2006 version in the office, on 2009 can not do cartiglio and square as in the old versions? is a bit elaborate but once it is done it is done.
x giorgio mandelli
once saved in drawing frame as I recall it?
I can insert in the configuration folder "drawing frame" my tamples with carts in various formats, how did you first edit the text file?
in xkè nn document properties can you change the size of the sheet (e.g. a4 to a3 hor or vert)?
xkè this need to change modes at the table?
