eliminare una borken view
  • Thread starter Thread starter dema
dema
often happens to get details starting from others and when this happens from a particular that was extremely long for which a broken view had been used, but the new detail is decidedly shorter it would be necessary to eliminate the broken view, but I with the wf2 never succeeded, in January we will pass to the wf4 there is someone who knows how to adjust a broken view?
at least from the wf4 it seems that the problem is solved, so from January I am in place anyway I leave track if someone else will have the same problem in the future, if someone knows how to do with the wf2
if I don't remember badly you can't change a broken view, the problem as you say rightly you were solved with the wf4, before you had to force things to delete the view and recreate it from 0.
There should still be a discussion about the subject. . .
Bye!
p-h
thank you so I just have to wait January when we pass to the wf4, I swear I had used the search function but the company for which I work decided to use the configuration in English language and just didn't think to look for "broken view" I had launched a search with broken view and not having found any result I opened a new discussion.
ma una domanda off topic:use all pro-e in Italian if you are satisfied, I for a while tried, but then I noticed some bad translations memory rounding instead of fitting, then some menus not translated, then I returned to the English version.
when I used it for work was in English, although honestly I prefer to have the menus in Italian... :wink:
p-h
I also use it in Italian and I feel good, not all translations are correct but cmq I can work more than well.
hello, in the meantime thanks to the news on the broken view, at the course they didn't say it... regarding the use of the English or Italian version, I found translations 'horried' for example the shrinkwrap, and for some commands it seems to me there was a bit of confusion (type regenerates and repaint if I don't remember bad), however according to me in the end it is only a fact of habit.
Bye!
without making names of companies, you were in that courtroom where half the computers didn't go. . .
