Special-one
hi to all the naval and sympathizers, I am new of this community I take care of design and realization drawings in particular yacht, the famine is the part according to me most influential on the project and the successful outcome of the ship.
in talking about large boats it has generally taken to illustrate what are their characteristics of style and design and it is perhaps a little neglected the exquisitely technical part, which is, instead, basic to allow these queens of the sea to carry out crossings in serene and safe navigation. I would like to illustrate the state of art in this area of construction and start from the base, from the hull, which can be displaced or semi-dislocated, according to the purposes of use.
round hull plans
the famine is, as it is known, the immersed part of the hull, called, with essential and very effective marine definition, also work alive, as with its forms directly influences the resistance and behavior of the boat during its motion and represents the vital part of each boat.
the choice of a displacement or semi-dislocating hull for a great motoryacht, as every designer knows, but also the owner with a little experience, the greater discriminants are dictated by two fundamental parameters: from the size of the hull and the speed at which you want to navigate. these, undoubtedly, are input that the designer receives directly from the owner and are the foundations on which to first develop the living work and then, subsequently, the internal and external layouts of the boat.
slender hulls
when to prefer one or the other? for an analysis on the choice of a certain form of hull, therefore, we begin to illustrate few simple concepts, which concern the resistance to the motion that a boat meets in water.
the resistance to the motion of a boat or ship, whatever its speed, size and type, depends mainly on two main phenomena:
water friction against the surface of the hull (strength resistance)
the generation, to the passage of the boat on the water, of surface waves (wave resistance)
to these two main factors should be added other, less conditional, but nevertheless important that we state below:
shape resistance
air resistance
resistance of appendages
resistance of dirty hull
resistance by sea
wave resistance and form resistance are commonly called globally residual or wave resistance.
the resistance of the dirty hull has much influence on the resistance of the ship especially with the going of time. in order to prevent the formation of dirt due to marine vegetation and microorganisms that are formed after long periods of sea especially in warm waters, the surface of the living work is treated with special antivigetative paintings, which periodically must be renewed.
is perhaps a difficult language to the most, but demonstrates in a concise and effective way the concept, accessible to all, that the friction resistance of a hull increases rapidly with the increase of speed, while the wave or residual resistance decreases, at equal speed, with the increase of the length to the float, that is the length measured on the "line that tracks the water level on the hull of the boat and separates the part immersed from that. In poor words, the more speed increases the more resistances increase to its progress, the longer the boat the greater is its speed of navigation.
the one who has to design a new ship or megayacht, therefore, is first faced with the problem of the consequences that will have on the power to install the possible choices of the shape of the hull and its proportions.
generally the problem is so formulated:
to seek, for the desired displacement (i.e., as far as you want to transport) and for the speed or speed you want, the forms and proportions of hull that will lead, without prejudice to the indispensable conditions of stability, to the least power consumption.
the project, according to operational requirements, can be developed following three basic directives:
the weight criterion
the volumetric criterion
the criterion for taxes dimensional limitations (which may be from time to time, depending on the needs of particular needs, width, length or dive).
the weight criterion is followed when the displacement of the ship is imposed by the loads of high specific weight, plus the weight of the hull and the motor apparatus. in this case (which only exceptionally can affect the nautical), the hull must have as much volume to contain the total weight listed above. we will find ourselves, therefore, in front of a ship with a pronounced immersion and therefore with a high volume of hull, remembering that the hull is the immersed part of the ship.
the volumetric criterion is followed when the ship must carry bulky loads, but of specific weight not elevated. in this case, ensured the necessary metacentric stability, it will be possible to carry much of this bulky load in spaces above the floating line; therefore, much of the useful volume of the ship will be over the float and the hull will be assigned that enough volume to bear the total weight.
However, the problem, in its more general formulation, will be to make travel a certain displacement at a certain speed, realizing or a fair of minimum length possible or of minimum power. as always in a boat, a compromise must be identified between the various needs, which meets the priorities of the shipowner.
the first case, which affects shipowners of ships, has advantages in the construction costs: Shorter ship however with a worse behaviour with rough sea, certainly more expensive in the exercise, as the apparatus requires more power to reach the same speed of a longer boat.
the second case, which affects the naval architect (i.e. the designer specialized in the study of static and dynamics of the hull), of the times is a little more expensive in the construction, for the greater length, but considerably less expensive in the exercise and with a better seal to the sea.
the third case, affects the shipowner who must travel the ship or the megayacht in low seabeds or passages in zones that bind the width, or particular constraints that condition the length. This third case could also affect those who, having sold a volume (a volumetric space) to a shipowner and stipulated the relevant contract, bind the main dimensions and then condition the coefficients of the hull.
This last case, sometimes, becomes the worst case for the naval architect, since the compromise in the choice of hydrodynamic coefficients will not be optimal.
but we examine one of the very frequent cases in the nautical, that of the priority of speed regarding the rest. If the speed becomes the primary data of the project, that is, there is a number of fades f > 0,6 or a quotient of taylor,
you should consider the shapes of edged famine that allow you to have a dynamic boost and achieve high speeds.
until now we have studied the resistances that meets the hull during his motorcycle; we see now the forms that best meet the various needs.
the forms that a carena can take are essentially two: round or corner.
the round hull, called displaced hull, with the increase of speed, has a wave resistance greater than that of friction, therefore it adapts better to the low and medium speeds. On the other hand, the edge hull, reached certain speeds, has a friction resistance that significantly exceeds the wave. The latter type of hull, called the planant hull, is therefore suitable for high speeds.
for the means that by weight, length and speed have intermediate characteristics between a round hull and a planant, the semi-planning or semi-dislocating hull is adopted. the latter compromise, used in the means of small tonnage, begins to be considered also for the ships of great tonnage and the hull is defined deep-v.
However, regardless of the forms of hull, a ship must maintain operational capacity under rough sea conditions.
However, it remains the fundamental consideration that the naval project, beginning with the choice of the hull and the very first forecasts of power, is not only a strictly mathematical study, determined and defined, but it is in reality how much more free and open can desire a creative mind.
the software has a relatively important function for the realization of the carena, it takes a general knowledge of the problems.
It's important to me once you have a superfice, choose a software with naval applications.
round hull plans
slender hulls
shape resistance
air resistance
resistance by sea
