fpaolelli
Hello, everyone!
I thank you for all the support provided to me during the stages of my work.
I came to the press and would like to confirm the exact procedure. basically I have to print the tables with certain colors but especially thicknesses. now I have assigned to each layer a different color that will have to be then shown in print with other colors I make an example I have the layer white (black in print) and the yellow pane layer in the final print the frame will have to be black with thickness 0.5 while the always black pane with thickness 0.4.
Now to do this I have created a print style(ctb file) where to white/black color I give the thickness 0.6 while to the other layer squares give the black color and 0.4 thickness.
at this point at the printer I deliver tables and ctb files right?
basically the colors of the layers serve only to have reference in the creation of the style then there I can change the color that will be printed and the thickness! I hope I've explained well!
Thank you again!
Thank you again!
