wildfire 5.0 su seven
  • Thread starter Thread starter luragne
luragne
Hello.
I'd like to know if anyone installed the 5.0 out of seven?
Are there any problems, or are everything smooth?
thank you very much to those who answer:redface:
Hello.
There are no problems, it certainly is better than with sight.
I remember that however the support is available for wf4.0 starting from m120 and wf5.0 starting from the m010 just released.
I would like to "bind" this topic, I hope it's correct.
is it possible to install vers.2 on seven?
I ask you this because after replacing the pc and installed windows 7 I can no longer install proe.
possible but not certified, the support of the wildfire2 stops at xp / xp 64 bit, perhaps it is for what you have problems.
Hello, on the laptop I installed view and it works.
with seven I tried the various compatibility options, but nothing.
Hello I have the version proewildfire 4.0 out of seven and it goes well I hope to have been of help
I don't know what to say, on the laptop PC it works all right, but if I try to install the same software on the fixed pc it doesn't work.
or better,I can not install,click on the set-up but then nothing more.
pc fixed :seven
PC port. :vista
I don't know.
hello and thanks again
pc fixed :seven
PC port. :vista
I don't know.
but it was said in this topic!
wf2 is not compatible with seven!!!
I exhume this old topic because I was born a problem: on windows 7 (64) home I am trying to install wf5 m020 and during the installation process requires me necessarily microsoft .net 3.5 to continue with installation. the fact is that the .net 3.5.1 is already installed and unlocked. Why don't you see him?
Thank you!
