grooves on sloping walls
  • Thread starter Thread starter sephirudex
sephirudex
Save to all...I would need a helper!!!I am fighting with a tilted wall.I created these walls tilted by covering a sloping mass and at the time when I try to create grooves on the wall cover I realize that revit selects only the perimeter vertical walls. Now, I thought I could act through the opening command, but I haven't tried yet, and the result I don't think is to the one I wanted.
p.s.: according to you to create metal arms that are protruding from a pylon and hold a glass wall (like a mega sticker) what is best to use?
thanks in advance for the solution to the double question and I hope to be able to trust in an answer of those powerful and resolute
benvenuto nel forum
use subtraction solids by extrusion on path
with the latest updates, you can also insert sloping pillars, curved beams, etc.
Welcome to the forum
Thank you very much, I will try. ..trying to understand how to use extruded solids (I think with local component command) and boleanize them
