and with the dead
  • Thread starter Thread starter Marcogeo
if I pick the symbol from the resources and place it with drag and drop on the wall takes it without problems ... now!
other curious thing that happens to me. if I move the symbol either manually or through the use of the "move" tool of the palette I lose the connection with the wall while if I use the tool you move from the menu correctly execute the command.
I think it's my lack of sensitivity to the software.
it works properly also by activating it.
question, to correctly place, right away, the object which tool you recommend to use?
I usually place a locus, which I use as a reference, at the exact point where I want my object to be inserted. but you can also use the tool to move objects found in the 2d toolbar, to reposition it or to duplicate it.
I do.
I don't know. It's the crucifix in the 2d blade, and there's also the 3d one in the modeling toolkit.
I do.
I think I'm embarrassing about software! reading your answer came to my mind to search among the library objects supplied to the software.
How can I import symbols folders without opening them one by one with the menu command open?
resource shovel: allows you to explore the resources of a file. from there select the folder and with ctrl click active the context menu, you will see the import item. at that point the folder of symbols is within the resources of your file.
I do.
through the search command, right? As long as I try, with the symbols key, I'm looking for 9941 files!! ! ! ! ! ! ! !
see what result I get and how I can use it!
This way it's a foul surrogate of the way you suggested me. Following your indication though, I would also rightly say, I go to explore the file folder containing the library after that I can select, one by one, what interests me but not the whole folder.
if the symbols are divided into folders you can import the folders, otherwise select the ones you need and import them.
a tip, it only matters what you need, don't burden the file unnecessarily.
I do.
doubt with the pillars:
I created pillars using the function creates pillars. These created pillars must be adapted to the depth of one roof. What better do I want to convert them to shape them?
I made an attempt with nurbs and managed to shape the whole but, in high/plant view, the filling attribute has disappeared although in the palette is still attributed. In practice, instead of seeing my pillar filled in gray I see it transparent but if I select it, it tells me that there are attributes.
Any advice?
If when you create a nurbs surface (with the command creates loft surface) you say creates solid makes you the solid you can assign the filling!
then, I am in a different operating mode than that quoted by zdr so I can not use the loft tool that would have been possible to use if I had started in the method indicated by him.
Now, given my situation, is there any notice to use?
Sorry, but I meant: remodel everything with the instrument I said... How did you work? Can you show us 1 screenshot?
The solids displayed in the plant are always transparent.
the only one is to transform them into hybrid symbols (if you always repeat the same however you want) so as to assign them also the 2d instance that in the plant you will see with filling.
I do.
I made an attempt but I don't understand why nothing changes. or better. I double-click the symbol and the edit window shows me, even in the plant, the symbol with the filling while when I return in the "normal" mode the symbol turns transparent though in the info window there is 2d/3d symbol written.
cmq, even in this mode I can not manage as I would like the object. In practice I would like to adapt the top of the pillar to the slope of the roof and instead I can not.
Any other advice?
